Product
Brand
iiyama Prolite E2480HS-B2 24" 2ms VGA DVI-D HDMI LED Monitor
Quicklinx: CB0CWS00 Mfr#: E2480HS-B2
Select:
The ProLite E2480HS is a 24" Full HD 1920 x 1080p LED-backlit monitor. It features 2ms response time and 12 000 000: 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for both home and office use.
Iiyama ProLite E2480HS-B2 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
57.15 cm x 21.35 cm x 40.1 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, TCO Displays 6.0
Display Type
Energy Class
Class A
32 kWh
21.8 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), i-Style Color
57.15 cm x 21.35 cm x 40.1 cm - with stand
4.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-4/+21
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management cover
1 x DVI cable , 1 x audio cable
22 Watt
Power Consumption Stand by
0.5 Watt
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10
Dimensions & Weight Details
With stand - width: 57.15 cm - depth: 21.35 cm - height: 40.1 cm - weight: 4.3 kg , Without stand - width: 57.15 cm - depth: 4.95 cm - height: 35.1 cm
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
CB0C C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.01
CB0C C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.85
CB0C C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.80
CB0C C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
CB0C C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £37.29
CB0C C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.44
CB0C C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £50.27
