The ProLite E2480HS is a 24" Full HD 1920 x 1080p LED-backlit monitor. It features 2ms response time and 12 000 000: 1 Advanced Contrast Ratio assuring clear and vibrant picture quality. Triple Input support of Analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star and TCO Certified. A reliable solution for both home and office use.
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
LED-backlight
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
- iiyama ProLite E2480HS-B2 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 21.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 57.15 cm x 21.35 cm x 40.1 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), i-Style Color
- Black
- 57.15 cm x 21.35 cm x 40.1 cm - with stand
- 4.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , HDMI , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -4/+21
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DVI cable , 1 x audio cable
- Input Voltage
- 21.8 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Microsoft Windows 95/98/ME/2000/XP/Vista/7/8, Windows 10
- Dimensions & Weight Details
- With stand - width: 57.15 cm - depth: 21.35 cm - height: 40.1 cm - weight: 4.3 kg , Without stand - width: 57.15 cm - depth: 4.95 cm - height: 35.1 cm
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
