iiyama ProLite E2283HS 22" 1920x1080 1ms VGA HDMI DisplayPort LED Monitor
Quicklinx: D79CWS00 Mfr#: E2283HS-B3
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
13 in stock
£82.31 ex VAT
£98.77 inc VAT
The ProLite E2283HS is an excellent LED-backlit monitor with high resolution. It features fast response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with installed graphics cards and embedded notebook outputs. The E2283HS is also equipped with two high quality stereo speakers.
  • Flicker free
    Controlling the monitor's brightness through electric current has allowed to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it.
  • OverDrive on/off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
    Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
iiyama ProLite E2283HS-B3 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
50.5 cm x 19.3 cm x 38.25 cm
3 kg
Environmental Standards
TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, VCCI Class B, CU
3-year warranty
Display Type
Energy Class
Class B
32 kWh
21.8 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -85
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
3 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DisplayPort , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
21 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 22in
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
