The ProLite E2283HS is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 2ms response time and more than 5000000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2283HS is also equipped with two high quality stereo speakers.
ACR
Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
Overdrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
Speakers
This LED monitor is equipped with two high quality stereo speakers.
- iiyama ProLite E2283HS - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 21.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.55 cm x 19.3 cm x 38.25 cm
- 3 kg
- Environmental Standards
- TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, VCCI Class B
- Display Type
- Energy Class
- Class B
- 32 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
- Black
- 3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 21.8 W
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
