iiyama ProLite E2282HS-B1 22" 1920x1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: DPW4WS00 Mfr#: E2282HSB1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
15 in stock
£86.54 ex VAT
£103.84 inc VAT
The ProLite E2282HS-B1 is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 1ms response time and 80 000 000: 1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. Triple Input support ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The E2282HS is equipped with two high quality stereo speakers. TCO Certified, this monitor is a reliable solution for both home and office use.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Flicker-free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite E2282HS-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
21.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Matte
Matte black
50.5 cm x 19.3 cm x 38.2 cm
3 kg
TUV GS, RoHS, WEEE, VCCI Class B, CU
Display Type
Energy Class
Class B
32 kWh
21.8 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Flicker Free technology, blue light reduction
Matte black
50.5 cm x 19.3 cm x 38.2 cm - with stand
3 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , Headphones (mini-jack) , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x audio cable
Security Slot Type
Kensington security slot
21 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 50.5 cm - depth: 19.3 cm - height: 38.2 cm - weight: 3 kg , Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm
5 °C
35 °C
10 - 80% (non-condensing)
iiyama ProLite E2282HS-B1 22 Bundle deal on iiyama ProLite E2282HS-B1 22" 1920x1080 1ms VGA DVI HDMI LED Monitor
£188.61
Diagonal Size: 22in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
