iiyama ProLite E2280WSD-B 22" 1680x1050 5ms VGA DVI-D Black Monitor with Speakers
Quicklinx: 8XQGWS00 Mfr#: E2280WSD-B1
The ProLite E2280WSD is a 22" 1680 x 1050 LED-backlit monitor. It features 5 ms black-to-black response time and 5,000,000:1 advanced contrast ratio assuring very good picture quality. Analog and DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is TCO and ENERGY STAR certified. A reliable solution for both home and office use.
iiyama ProLite E2280WSD-1 - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
51.25 cm x 20.45 cm x 39.55 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+85 / -85
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
HDCP
3.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
26
VESA Mounting Interface
100 x 100 mm
Stand, cable management cover
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
TUV GS, VESA DPMS
Power Supply
Internal
21 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Driver
ENERGY STAR Certified
8XQG C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.26
8XQG C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.65
8XQG C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.51
8XQG C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
8XQG C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.95
