iiyama ProLite E2280HS 22" 1920x1080 5ms HDMI DVI-D VGA Black Monitor with Speakers
Quicklinx: 8W98WS00 Mfr#: E2280HS-B1
Select:
  • 22"
The ProLite E2280HS is a 21.5" Full HD 1920 x 1080p LED-backlit monitor. It features 5ms black-to-black response time and >5,000,000: 1 advanced contrast ratio assuring very good picture quality. Triple input support of analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded notebook outputs. The monitor is ENERGY STAR Certified. It offers a reliable solution for both home and office use.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • ACR (Advanced Contrast Ratio)
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HDMI (High-Definition Multimedia Interface)
    HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite E2280HS-1 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
23.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2482 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
50.95 cm x 18.95 cm x 36.55 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS
Display Type
Energy Class
Class B
35 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2482 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
3.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , HDMI , Audio line-in
Mechanical
Tilt
Tilt Angle
-4/+21
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
Input Voltage
23.8 W
Power Consumption (Typical)
21 Watt
Power Consumption Stand by / Sleep
1 Watt
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Sustainability Information
Accessories (4)
8W98 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.78
8W98 StarTech.com Articulating Monitor Arm In Stock £132.69
8W98 StarTech.com Dual Monitor Stand In Stock £91.06
8W98 StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
Other bundles (1)
8W98 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
