iiyama ProLite E2083HSD-1 19.5" 1600x900 5ms VGA DVI-D LED LCD Black Monitor with Speakers
Quicklinx: 900LWS00 Mfr#: E2083HSD-B1
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
25 in stock
£80.70 ex VAT
£96.84 inc VAT
The ProLite E2083HSD is a 19.5" LED-backlit monitor with 1600 x 900 resolution. It features 5msec response time and more tan 5M: 1 advanced contrast ratio assuring vibrant images and blur free video. Analog VGA and digital DVI inputs ensure compatibility with the systems and associated graphics cards. The monitor is Energy Star qualified and VESA mount compatible.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and makes this LCD a true ECO-friendly product.
  • ACR
    Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
iiyama ProLite E2083HSD-1 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
46.95 cm x 20.3 cm x 36 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, DDC/CI, GOST-R, VCCI Class B
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, luminance
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
2.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand, 3 screws
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
15 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
iiyama ProLite E2083HSD-1 19.5 Bundle deal on iiyama ProLite E2083HSD-1 19.5" 1600x900 5ms VGA DVI-D LED LCD Black Monitor with Speakers
£179.87
900L C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.80
900L C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.11
900L C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.55
900L C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
900L C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.46
Diagonal Size: 20in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
