The ProLite E2083HD is a 19.5" LED-backlit monitor with 1600 x 900 resolution. It features 5 ms response time and more than 5M:1 advanced contrast ratio assuring vibrant images and blur free video. Analog VGA and digital DVI inputs ensure compatibility with the latest systems and associated graphics cards. The monitor is ENERGY STAR qualified and VESA mount compatible. It is a reliable solution for both home and office use.
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
ACR (Advanced Contrast Ratio)
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. ACR (Advanced Contrast Ratio) is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite E2083HD-B1 - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.95 cm x 20.3 cm x 36 cm
- 2.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST-R, VCCI Class B
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, input select, phase, clock, luminance
- OSD Languages
- English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Advanced Contrast Ratio (ACR)
- Black
- 2.6 kg
- DVI-D , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
Sustainability Information
- ENERGY STAR Certified
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
