iiyama Prolite C1911S-3 19" 1280x1024 5ms VGA LED-backlit LCD CCTV Monitor
Quicklinx: 99MFWS00 Mfr#: C1911S-B3
Prolite C1911S-3 is a 19" LED-backlit LCD display designed for demanding CCTV and broadcast applications. The 19" CCTV display features a fast 5 m/s response time and a 1000:1 contrast ratio offering great color performance with clear and vivid images. This CCTV is also a real eco-friendly product using LED-backlight which reduces the typical power consumption.
  • CCTV
    This CCTV monitor is designed for demanding CCTV and broadcast applications. VESA compliance allows for easy installation in any surveillance and security environment.
  • LED-backlight
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
iiyama ProLite C1911S-3 LCD display
LCD display
Recommended Use
Surveillance system
Supported Image Aspect Ratio
5:4
Colour Support
Display Size
19"
Resolution
1280 x 1024
LCD Technology
TFT active matrix
Built-in Speakers
2 speakers
AC 120/230 V
Power Consumption
19 Watt
2 years
LCD display
40.7 cm
20.1 cm
43.2 cm
3.9 kg
CCTV
Equipment Category
CCTV monitors
Security DVR
Image Resolution
1280x1024
Studio & Field Monitors
Recommended Use
Surveillance system
5:4
Colour Support
Display Size
19"
Native Resolution
1280 x 1024
LCD Technology
TFT active matrix
Built-in Speakers
2 speakers
AC 120/230 V
Frequency
50/60 Hz
Power Consumption
19 Watt
Terminals
Terminals
(1) x VGA input - 15 pin HD D-Sub (HD-15) , (1) x audio line-in , (2) x composite video output - BNC , (2) x composite video input - BNC
Warranty
2 years
