iiyama ProLite B2875UHSU-B1 28" 3860x2160 1ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FJ14WS00 Mfr#: B2875UHSU-B1
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
30 in stock
£273.66 ex VAT
£328.39 inc VAT
Do you want a single screen? Still you need to simultaneously display content from different input sources? Great! The Iiyama B2875UHSU is exactly what you are looking for. Featuring 4K resolution, the monitor offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. PIP and PBP features allow users to easily create their own work space by displaying and manipulating multiple applications from two different data sources. In addition, the high-quality panel offers high performance with great color reproduction and a fast response time, and the height adjustable stand allows you to adjust the screen position to your preferences. Powerful and useful - Iiyama B2875UHSU - your monitor for years to come.
  • 4K resolution
    UHD resolution, better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI, it displays an incredibly sharp and crisp image.
  • Height adjustable stand
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • Blue light reducer
    As you know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen. The monitor's brightness and color temperature is adjusted through an excellent feature called Blue light reduction easily accessible through the monitor's OSD menu.
  • PIP function
    PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time.
iiyama ProLite B2875UHSU-B1 - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
80 kWh
Power Consumption (On mode)
54.9 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, MHL, DVI, DisplayPort, VGA
Display Position Adjustments
Height, swivel, tilt
65.95 cm x 23 cm x 41.05 cm
7.5 kg
VESA DPMS, TUV Bauart, VCCI Class B, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class C
80 kWh
54.9 W
Diagonal Size
28"
Viewable Size
28"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
30 - 75 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
Picture in picture, picture by picture, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Black Tuner
7.5 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
VGA , DVI , USB , Headphones , DisplayPort , HDMI , MHL / HDMI
Mechanical
Tilt Angle
17
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x Mini DisplayPort cable - DisplayPort to DisplayPort , 1 x USB cable , 1 x audio cable
AC 100/240 V (50/60 Hz)
44 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows
Limited warranty - 3 years
iiyama ProLite B2875UHSU-B1 28 Bundle deal on iiyama ProLite B2875UHSU-B1 28" 3860x2160 1ms VGA HDMI DisplayPort LED Monitor
£372.83
Diagonal Size: 28in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 150 - 300
