iiyama ProLite B2791QSU-B1 27" 2560 x 1440 1ms DVI HDMI LED Monitor
Quicklinx: DLWQWS00 Mfr#: B2791QSU-B1
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
18 in stock
£220.76 ex VAT
£264.91 inc VAT
Looking at a screen for long hours can be quite tiring for the eyes. But it doesn't have to. The 27" iiyama ProLite B2791QSU is big enough to make sure you can clearly see every detail and it comes equipped with technologies to help keep your vision intact.
The B2791QSU offers WQHD (2560 x 1440) resolution meaning the screen can accommodate almost 77% more information than a Full HD display. Email and excel will fit in nicely next to each other. The panel backlight is flicker free and the blue light reducer function limits the amount of blue, the most unfavorable, light emitted by the screen.
The height adjustable stand allows you to easily adjust the screen position to make sure you are looking at it at the right angle. DVI, HDMI and DisplayPort inputs along with a USB hub assure broad connectivity options. And as the monitor offers 1 ms response time and supports FreeSync technology, it can serve not only as your workplace companion, but also to play games and watch movies.
  • WQHD
    With true WQHD 2560 x 1440p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen, i.e. over 76% more in comparison to a 1920 x 1080 monitor.
  • HAS + Pivot
    With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width.
  • Flicker free + Blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite B2791QSU-B1 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
35.7 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1440p (Quad HD) 2560 x 1440 (DisplayPort: 75 Hz, HDMI: 70 Hz, DVI: 60 Hz)
Pixel Pitch
0.223 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Screen Coating
Matte
61.1 cm x 23 cm x 39.7 cm
6.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, CU
Display Type
Energy Class
Class B
52 kWh
35.7 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.223 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, FreeSync Technology
61.1 cm x 23 cm x 39.7 cm - with stand
6.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , HDMI , DVI , Headphones (mini-jack) , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x HDMI cable , 1 x USB cable , 1 x DisplayPort cable
33 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 61.1 cm - depth: 5.4 cm - height: 37.15 cm , With stand - width: 61.1 cm - depth: 23 cm - height: 39.7 cm - weight: 6.1 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama ProLite B2791QSU-B1 27 Bundle deal on iiyama ProLite B2791QSU-B1 27" 2560 x 1440 1ms DVI HDMI LED Monitor
£319.93
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
