The ProLite B2783QSU is an excellent 27" QHD LED-backlit monitor bringing the world of business and gaming together. The monitor offers accurate and consistent color reproduction with wide viewing angles and a sharp high resolution panel. Its ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. This monitor features FreeSync technology, offering gamers the chance to experience fluid and fracture free gaming. Triple input and a USB hub ensure compatibility with your desktop PC or notebook.
Blue light reducer
As you know looking at a monitor screen for several hours per day, especially form a closer distance, causes eye fatigue. This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows your eyes to feel less tired while working long hours with a computer screen. It was achieved by adjusting the monitor's brightness and color temperature through a feature Blue light reduction easily accessible through the monitor's OSD menu. -
Overdrive on / off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the Overdrive feature will eliminate that. -
Speakers and headphones
Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
- iiyama ProLite B2783QSU-B1 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 43 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2333 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey), 5 ms (typical)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.25 cm x 23 cm x 40.05 cm
- 6.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, DDC/CI, PSE Mark, VCCI Class B
- Display Type
- Energy Class
- Class B
- 62 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2333 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K
- Controls & Adjustments
- Volume, brightness, contrast, sharpness, input select, colour temperature
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction, i-Style Color
- Black
- 62.25 cm x 23 cm x 40.05 cm - with stand
- 6.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort , DVI-D , HDMI , Headphones , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-in
Mechanical
- Tilt Angle
- -5/22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x SuperSpeed USB cable
- Input Voltage
- 43 W
- Power Consumption (Typical)
- 44 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- Dimensions & Weight Details
- Without stand - width: 62.25 cm - depth: 5.65 cm - height: 37.25 cm , With stand - width: 62.25 cm - depth: 23 cm - height: 40.05 cm - weight: 6.1 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
