iiyama ProLite B2483HSU-B1DP 24" 1920x1080 2ms VGA DVI-D DisplayPort LED Monitor
Quicklinx: B1DWWS00 Mfr#: B2483HSU-B1DP
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
45 in stock
£130.99 ex VAT
£157.18 inc VAT
The ProLite B2483HSU is an excellent 24" Full HD LED-backlit monitor. Triple Input (incl. DisplayPort) support and USB HUB ensure compatibility with the latest installed graphics cards and embedded Notebook outputs. The ergonomic stand offers 13 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. The monitor is TCO6 and Energy Star Certified. A perfect solution for education, local government, business and finance markets.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • HAS + Pivot
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • Flicker free
    Controlling the monitor's brightness through electric current has allowed to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it.
  • Overdrive On / Off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
iiyama ProLite B2483HSU-B1DP - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
56.55 cm x 23 cm x 38.65 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, TCO Displays 6.0, VCCI Class B
Display Type
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, luminance
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology
5.2 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D (HDCP) , VGA , DisplayPort (HDCP) , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable
Power Supply
Internal
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
ENERGY STAR Certified
iiyama ProLite B2483HSU-B1DP 24 Bundle deal on iiyama ProLite B2483HSU-B1DP 24" 1920x1080 2ms VGA DVI-D DisplayPort LED Monitor
£230.16
B1DW C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.49
B1DW C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.63
B1DW C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
B1DW C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.82
B1DW C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.54
B1DW C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.49
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
