The ProLite B2480HS is a high specification 24" Full HD 1920 x 1080p LED-backlit monitor with Height Adjustability and Screen Rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 2ms response time and >5 000 000 : 1 Advanced Contrast Ratio make the B2480HS ideal for video conferencing, DTP and CAD as well as the usual text based applications. Triple input support of analog, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs. The monitor is Energy Star and TCO certified.
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
HAS
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
Pivot
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
- iiyama ProLite B2480HS-W1 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 23.8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 57.15 cm x 24.45 cm x 42.7 cm
- 6.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B
- Display Type
- Energy Class
- Class B
- 35 kWh
- Diagonal Size
- 24"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2715 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- sRGB colour management, HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR)
- White
- 6.1 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D , VGA , HDMI , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 23.8 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- 0.5 Watt
- OS Required
- Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
