The ProLite B2280WSD is a high specification 22" 1680 x 1050 LED-backlight monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. 5 millisecond black-to-black response time and 5000000:1 advanced contrast ratio make the B22080WSD ideal for video conferencing, DTP and CAD as well as the usual text based applications. Analog and DVI inputs ensure compatibility with the systems and associated graphics cards.
LED-backlight
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product. -
ACR
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall. -
Speakers
This LED monitor is equipped with two high quality stereo speakers. -
Height adjustable stand
A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. -
Pivot
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
- iiyama ProLite B2280WSD-1 - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- White
- 51.25 cm x 24.45 cm x 42.35 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VESA DPMS, TCO Displays 5.0
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +85 / -85
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
- OSD Languages
- English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- White
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- DVI-D (HDCP) , VGA , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 21 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
- ENERGY STAR Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.76 | in stock |
£225.06
C2G 1m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £7.95 |
C2G 2m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £9.31 |
C2G 5m DVI-D™ M/M Dual Link Digital Video Cable | In Stock | £16.89 |
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL | In Stock | £10.82 |
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter | In Stock | £5.00 |
C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter | In Stock | £7.59 |
C2G USB to DVI Adapter Up To 2048 x 1152 | In Stock | £38.98 |
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £8.65 |
C2G Pro DVI-D to VGA Converter - Video converter - Black | In Stock | £52.51 |
