iiyama Prolite B2083HSD-B1 20" 1600x900 5ms VGA DVI-D LED Monitor
Quicklinx: 961GWS00 Mfr#: B2083HSD-B1
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
Select:
  • 20"
More than 50 in stock
£92.40 ex VAT
£110.88 inc VAT
The ProLite B2083HSD is a 19.5" 1600 x 900 LED-backlit monitor with a Height Adjustable Stand supporting screen rotation, ensuring perfect posture and optimal viewing comfort. It features 5 msec black-to-black response time and 5 000, 000: 1 Advanced Contrast Ratio assuring very good picture quality. The monitor is TCO6 and Energy Star certified. A perfect solution is design for education, local government, business and finance markets.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true eco-friendly product.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • HAS
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • Pivot
    Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
iiyama ProLite B2083HSD-1 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
46.95 cm x 23 cm x 35.65 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, DDC/CI, GOST-R, VCCI Class B
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, clock, luminance
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
4.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
15 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
iiyama Prolite B2083HSD-B1 20 Bundle deal on iiyama Prolite B2083HSD-B1 20" 1600x900 5ms VGA DVI-D LED Monitor
£191.57
961G C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.89
961G C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.23
961G C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.77
961G C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
961G C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.52
961G C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.58
Diagonal Size: 20in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 50 - 100
