iiyama ProLite B1980SD-B1 19" 1280x1024 5ms LED LCD DVI-D VGA Black Monitor with Speakers
Quicklinx: 8RK8WS00 Mfr#: B1980SD-B1
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
43 in stock
£114.62 ex VAT
£137.54 inc VAT
The 19" ProLite B1980SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1980SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately.
  • HAS
    A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product.
  • ACR
    Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • PIVOT
    Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
iiyama ProLite B1980SD-B1 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
41.1 cm x 24.45 cm x 42.65 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS, TCO Displays 5.0, VCCI Class B
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+75 / -85
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
320
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable - VGA to VGA , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
16 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8
ENERGY STAR Certified
iiyama ProLite B1980SD-B1 19 Bundle deal on iiyama ProLite B1980SD-B1 19" 1280x1024 5ms LED LCD DVI-D VGA Black Monitor with Speakers
£213.79
8RK8 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.85
8RK8 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.88
8RK8 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.17
Diagonal Size: 19in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
