iiyama ProLite B1780SD-B1 17" 1280x1024 5ms VGA DVI-D LED Monitor
Quicklinx: B1DNWS00 Mfr#: B1780SD-B1
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
£105.27 ex VAT
£126.32 inc VAT
The 17" ProLite B1780SD designed for business usage is a LED-backlit monitor with height adjustability and screen rotation allowing you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort. The 5 ms response time and high contrast make the B1780SD ideal for a wide range of business applications. sRGB and gamma correction functions permit even the finest nuances of color to be set accurately. The ProLite B1780SD includes DVI and VGA connectivity.
  • HAS
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • LED-backlight
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-friendly product.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • PIVOT
    Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • VESA
    VESA mount compliance means you can easily mount your monitor to a wall.
iiyama ProLite B1780SD-1 - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
37 cm x 23 cm x 39.95 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
VESA DPMS, GOST-R, TUV Bauart, VCCI Class B
3-year warranty
Display Type
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock, luminance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
4.4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt Angle
-3/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand, cable management cover
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
Power Supply
Internal
14 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
ENERGY STAR Certified
Limited warranty - 3 years
iiyama ProLite B1780SD-B1 17 Bundle deal on iiyama ProLite B1780SD-B1 17" 1280x1024 5ms VGA DVI-D LED Monitor
£204.44
B1DN C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.83
B1DN C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.23
B1DN C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.60
B1DN C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.58
Diagonal Size: 17in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
