iiyama ProLite 27" XB2779QQS-S1 5120x2880 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: DGG4WS00 Mfr#: XB2779QQS-S1
Diagonal Size: 27in
Max Resolution: 5120 x 2880
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£570.31 ex VAT
£684.37 inc VAT
Featuring 5K (5120 x 2880) resolution, the XB2779QQS can display 14,7 megapixels on the screen - a stunning 7 times more than a Full HD monitor. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The IPS matrix guarantees high performance with accurate and consistent color reproduction and wide viewing angles. The XB2779QQS is perfect for graphic and web design.
  • 5K resolution
    5K (5120 x 2880) resolution means a monitor can display 14.7 megapixels on the screen - a stunning 7 times more than a Full HD monitor.
  • IPS technology
    IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Flicker free + blue light
    The ultimate solution for the comfort and health of your eyes. Flicker free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light emitted by the screen and responsible for your eyes feeling fatigued substantially reduced.
  • Height adjustable stand
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama ProLite XB2779QQS-S1 - LED monitor - 5K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class D
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K 5120 x 2880 at 60 Hz
Pixel Pitch
0.116 mm
Brightness
440 cd/m²
Contrast Ratio
1200:1 / 80000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Silver
65 cm x 23 cm x 43.45 cm
8.2 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Display Type
Energy Class
Class D
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.116 mm
Brightness
440 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 180 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Japanese, Chinese
Picture in picture, picture by picture, Eco-Mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color
Silver
8.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x DisplayPort , 3 x HDMI , Headphones
Mechanical
Tilt Angle
-2/+17
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
60 Watt
ENERGY STAR Certified
iiyama ProLite 27 Bundle deal on iiyama ProLite 27" XB2779QQS-S1 5120x2880 4ms HDMI DisplayPort IPS LED Monitor
£669.48
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 500 - 750
