iiyama ProLite 24" 1920x1080 4ms HDMI DVI-D VGA LED Monitor
Quicklinx: D3T9WS00 Mfr#: X2483HSU-B3
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
24 in stock
£111.11 ex VAT
£133.33 inc VAT
ProLite X2483HSU-B3 - a 24" LED backlit LCD Screen featuring AMVA panel technology, guarantees accurate and consistent colour reproduction with wide viewing angles. Offering 24 bit ‘True Colour’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite X2483HSU-B3 will provide excellent performance for Photographic, Design and Web-design. With the added support of a Low Power LED Panel, the iiyama Prolite X2483HSU-B3 is an excellent choice for Universities, Corporate and Financial Markets.
  • Flicker-free and blue light
    The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with blue light reducer function. Absolutely no flickering. And the amount of blue light, emitted by the screen and responsible for your eyes feeling fatigued, substantially reduced.
  • AMVA
    AMVA technology offers higher contrast, darker blacks and much better viewing angles. The screen will look good, no matter what angle you look at it.
  • OverDrive on/off
    When very fast graphics are displayed, your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • ACR
    Advanced contrast ratio is a feature, that automatically adjusts contrast and brightness of the screen to assure perfect picture quality, while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high-definition images. This means you can accommodate more information on your screen.
iiyama ProLite X2483HSU-B3 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
55.25 cm x 20.3 cm x 40.65 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC-2B, VESA DPMS, PSE Mark, TCO Displays, VCCI Class B, CU
Display Type
Energy Class
Class B
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
3.9 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DisplayPort , HDMI , Headphones (mini-jack) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x HDMI cable
26 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
ENERGY STAR Certified
iiyama ProLite 24 Bundle deal on iiyama ProLite 24" 1920x1080 4ms HDMI DVI-D VGA LED Monitor
£210.87
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
