The ProLite B2283HS is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features short response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. Triple input support ensures compatibility with the installed graphics cards and embedded notebook outputs. The ergonomic stand offers height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments, where workplace flexibility and ergonomics are key factors. The monitor is TCO certified. A perfect solution for education, local government, business and finance markets.
HAS and pivot
With a height adjustable stand you will create an ergonomic work posture and position, that meets all health and safety requirements. This will not only prevent any health issues, but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful, if the application requires more height than width. -
Flicker-free
Controlling the monitor's brightness through electric current has allowed to eliminate the screen flicker. You can easily test it yourself - just look at the screen via you smartphone's camera. Your eyes will love it. -
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Speakers and headphones
Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up. -
ACR
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature, that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite B2483HS-B3 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 24.9 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Matte
- Black
- 56.55 cm x 23 cm x 38.65 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VESA DPMS, PSE Mark, VCCI Class B, CU
- Display Type
- Energy Class
- Class A
- 36 kWh
- 24.9 W
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
- Black
- 5.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , HDMI , Headphones , DisplayPort , Audio line-in
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- ENERGY STAR Certified
