Iiyama P1905S-B2 19" 1280x1024 5ms VGA DVI-D LED Monitor
Quicklinx: 967TWS00 Mfr#: P1905S-B2
The ProLite P1905S meets the increasing demands for protected LCDs within education, retail and industrial applications. In addition to having toughened safety glass fitted behind the bezel at 8H hardness rating capable of resisting above normal impacts to the display, Iiyama have enhanced the range to include the latest high performance and energy saving technology. Features include 5 ms response time, 1000:1 contrast ratio enhancing color and analog and DVI inputs. The displays are ENERGY STAR rated and have 19 W typical power consumption in use and less than 1 W in standby.
  • Protective glass
    The toughened safety glass fitted behind the bezel at 8H hardness rating is capable of resisting above normal impacts to the display making this LCD the ideal choice for Education, Retail and Industrial applications.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
  • Speakers
    This LED monitor is equipped with two high quality stereo speakers.
  • Key lock
    You can easily lock and unlock the front controls preventing unauthorized changes to settings you made.
iiyama ProLite P1905S-2 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
8H Hard Coating
Voltage
41.45 cm x 20.05 cm x 42.05 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, VESA DPMS
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -70
Screen Coating
8H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, phase, clock
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
Protective Glass Panel
4.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
TUV GS, VESA DPMS
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
1 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista, Microsoft Windows 7 / Windows 8
Sustainability Information
ENERGY STAR Certified
967T C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
