iiyama MD BRPCV01/VESA Mount Bracket SFF - White
Quicklinx: B1K3WS00 Mfr#: MD BRPCV01-W
MD BRPCV01 is a high quality bracket that allows a Mini PC or Thin Client to be mounted to the iiyama Height Adjustable stand. This solution is compatible with almost all ThinClient/ZeroClient PC's and with basically all iiyama 19'' to 24'' height adjustable monitors.
Iiyama thin client to monitor mounting bracket
Thin client to monitor mounting bracket
White
ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2
White
Iiyama ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2
