MD BRPCV01 is a high quality bracket that allows a Mini PC or Thin Client to be mounted to the iiyama Height Adjustable stand. This solution is compatible with almost all ThinClient/ZeroClient PC's and with basically all iiyama 19'' to 24'' height adjustable monitors.
- Iiyama thin client to monitor mounting bracket
- Product Type
- Thin client to monitor mounting bracket
- White
- Designed For
- ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2
- Product Type
- White
- Designed For
- Iiyama ProLite B1980SD-B1, B1980SD-W1, B2280HS-1, B2280HS-B1DP, B2280WSD-1, B2480HS, B2480HS-2, B2480HS-W1, B2481HS-1, XB2380HS, XB2485WSU, XB2485WSU-1, XB2485WSU-2
