iiyama Iiyama ProLite LH5510HSHB-B1 75" digital display
Quicklinx: DXXQWS00 Mfr#: LH7510USHB-B1
Marketing description is not available.
  • Sunlight readable
    This display features a high-brightness which makes it ideal for brightly-lit environments and sunny locations such as shop windows. The high-brightness ensures that your content is always clearly visible even when the sun is shining directly on your display.
  • LED blackening effect free
    LED blackening or solar clearing happens when a regular LED display is installed in a location with direct sunlight on the display. The sunlight will heat-up the display and cause the LED's to discolor and eventually turn black. A blackening effect free LED panel is specially designed to withstand higher temperatures up to 110 degrees Celsius of the LED panel preventing discoloration of the LED cells because of direct sunlight exposure.
iiyama ProLite LH7510USHB-B1 75" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Matte black
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Frequency
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
IPS-M+
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
Energy Class
Class D
538 Watt
Power Consumption (On mode)
357.9 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
785 kWh
168.2 cm x 9.95 cm x 96.05 cm
76 kg
Energy Class
Class D
538 Watt
357.9 W
785 kWh
Diagonal Class
75"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Brightness sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
168.2 cm
9.95 cm
96.05 cm
76 kg
Enclosure Colour
Matte black
Display
LCD Display Technology
IPS-M+
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Frequency
LED backlight
Image Contrast Ratio
1200:1
Brightness
3000 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Display Menu Language
English
Blackening Defect Free, sunlight readable, picture in picture (no tuner)
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm, 600 x 200 mm
VESA Compatibility
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x main channel speaker - 5 Watt
Connector Type
DVI-D input , HDMI input , DisplayPort input , Audio input , RS-232C input
HDMI cable - 1.8 m , Serial cable - 1.8 m , Sensor cable
DDC-2B, CB, REACH, SVHC, CU
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
190.3 cm
Depth (Shipping)
26.5 cm
Height (Shipping)
122 cm
45 °C
