See the difference with the ProLite professional signage display. Featuring a slim bezel and an IPS LED panel for exceptional color and image performance, it offers businesses an easy and effective solution to successfully help them get their message across to the clients.
- iiyama ProLite LE8640UHS-B1 86" Class (85.6" viewable) LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- Yes - digital signage
- Matte black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15), HDMI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Open Pluggable Standard (OPS) support
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 302 Watt
- Power Consumption (On mode)
- 290 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 441 kWh
- Dimensions (WxDxH) - without stand
- 192.79 cm x 8.59 cm x 142.7 cm
- 63.8 kg
- Product Type
- Energy Class
- Class B
- 302 Watt
- 290 W
- 441 kWh
- Diagonal Class
- 86"
- Diagonal Size
- 85.6"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- Modes
- Landscape mode
- Design
- Fanless Design
- Dimensions
- Without stand
- 192.79 cm
- 8.59 cm
- 142.7 cm
- 63.8 kg
- Enclosure Colour
- Matte black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 410 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Anti Image Retention Circuitry (AIR)
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Streaming media playback
- Connectivity
- LAN
- Connector Type
- VGA input , 4 x HDMI input , DisplayPort input , Audio input , RS-232 input , LAN , Infrared input , 2 x audio output , RS-232 output , Loop thru output , USB 2.0
- Batteries
- Cables Included
- HDMI cable , Mini DisplayPort-DisplayPort cable , Serial cable
- Plug and Play, DDC-2B, CB, TUV Bauart, CU, DisplayPort 1.2
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 222.4 cm
- Depth (Shipping)
- 37.3 cm
- Height (Shipping)
- 142.7 cm
- 0 °C
- 40 °C
