iiyama GB2788HS-B2 27" 1920 x 1080 1ms DVI HDMI DP Gaming Monitor
Quicklinx: CW3NWS00 Mfr#: GB2788HS-B2
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£242.32 ex VAT
£290.78 inc VAT
The G-MASTER Red Eagle gives true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering response time, ensuring fluid and accurate transition between the images.
  • Custom gaming modes
    Have it your way. Choose one of the predefined gaming modes or set and memorize your own settings.
  • Fast response time
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance
  • Black tuner
    The users can adjust the brightness and the dark shades with the black tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • High-quality speakers
    Enjoy using the integrated high-quality speakers. Or plug your headset to the headphone socket and turn up the volume.
iiyama G-MASTER Red Eagle GB2788HS-B2 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
34 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, swivel, tilt
64.35 cm x 23 cm x 41.2 cm
6.9 kg
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
Display Type
Energy Class
Class B
49 kWh
34 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 145 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Japanese
HDCP, Eco-Mode, Overdrive technology, game mode, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, FreeSync Technology, Black Tuner
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
DisplayPort , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
17
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x DisplayPort cable - DisplayPort to DisplayPort
35 Watt
iiyama GB2788HS-B2 27 Bundle deal on iiyama GB2788HS-B2 27" 1920 x 1080 1ms DVI HDMI DP Gaming Monitor
£342.08
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
