The 27" G-MASTER GB2783QSU opens you to a whole different level of gaming experiences. The Silver Crow makes sure all the finest details are displayed with perfect image clarity. Nothing will skip your attention. The blue light reducer function along with the flicker-free panel are the shield your eyes need to guarantee your vision remains well protected. Armed with FreeSync technology and 1 ms response time the Silver Crow is ready to lead you into the toughest battles, leaving nothing to chance - the faith of your gaming destiny rests in your hands alone.
- iiyama G-MASTER Silver Crow GB2783QSU-B1 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 42.6 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.25 cm x 23 cm x 40.05 cm
- 6.1 kg
- TUV GS, DDC-2B, VESA DPMS, DDC/CI, CU
- Display Type
- Energy Class
- Class B
- 62 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction
- Black
- 6.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort (HDCP) , DVI-D (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
- Input Voltage
- 42.6 W
- Power Consumption (Typical)
- 44 Watt
- Power Consumption Stand by
- 0.5 Watt
