iiyama Gas Spring Mounting Arm
Quicklinx: D1BMWS00 Mfr#: DS3001C-B1
£75.64 ex VAT
£90.76 inc VAT
The iiyama DS3001C-B1 is a desk mount (grommet or clamp) for flat screens up to 27". Using the arm guarantees you gain additional space on your desk and the cable management system helps to keep the workplace tidy. But more importantly, offering broad adjustment capabilities including tilt, swivel, height and rotation, the arm makes sure you can easily adjust the screen position to your preferences assuring ergonomic body posture.
Iiyama DS3001C-B1 - desk mount (adjustable arm)
Desk mount (adjustable arm)
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Recommended Use
Monitor
Recommended Display Size
10"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
Monitor
Cable Management
Integrated cable management
10"-27"
Tilt
-85° to 15°
Pan
360°
Rotation
90°
Max Load Weight
5 kg
Min Load Weight
1.5 kg
Details
Gas spring lift
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1
Brand: iiyama
Price Range Ex VAT: 50 - 100
