Product
iiyama G-MASTER Red Eagle 27" Full HD 1ms DVI-D HDMI DisplayPort LED Monitor
Quicklinx: BRMQWS00 Mfr#: GB2788HS-B1
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£242.32 ex VAT
£290.78 inc VAT
Red Eagle - fly high with your ultimate partner in battle
The 27'' G-MASTER GB2788HS known as Red Eagle is a real game changer, giving true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering 1 ms response time, ensuring fluid and accurate transition between the images. Armed with FreeSync technology and 144Hz refresh rate, this powerful predator has no mercy for ghosting effects or smearing issues. Perfect vision manifested in the ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. No matter which you prefer: RTS, FPS, MOBA and MMO - choose Red Eagle and rank yourself top of the gamer community food chain.
144 Hz
Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144hz refresh rate delivers the crisp and sharp images needed to raise your game. For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI.
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • 144 Hz
  • FreeSync technology
    AMD FreeSync technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
  • 1 ms
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
  • Black Tuner
  • OverDrive On/Off
  • Speakers and headphones
iiyama G-MASTER Red Eagle - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
34 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, swivel, tilt
64.35 cm x 23 cm x 41.2 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class B
49 kWh
34 W
Diagonal Size
27"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 145 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, black level
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
17
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable
35 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8, Windows 10
ENERGY STAR Certified
iiyama G-MASTER Red Eagle 27 Bundle deal on iiyama G-MASTER Red Eagle 27" Full HD 1ms DVI-D HDMI DisplayPort LED Monitor
£342.08
BRMQ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BRMQ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.40
BRMQ C2G 5m Select High Speed HDMI with Ethernet In Stock £21.38
BRMQ C2G 10m Select High Speed HDMI with Ethernet In Stock £41.06
BRMQ C2G Pro HDMI to VGA Converter In Stock £51.28
BRMQ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
