iiyama G-MASTER Golden Phoenix 28" 4K 3860x2160 1ms HDMI
Quicklinx: BRMTWS00 Mfr#: GB2888UHSU-B1
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mobile High-Definition Link (MHL), VGA (HD-15)
£301.76 ex VAT
£362.11 inc VAT
GOLD PHOENIX - 28" G-MASTER 4K monitor supporting FreeSync™ technology
The 28" G-MASTER GB2888UHSU known as Gold Phoenix, features 4K (3840 x 2160) resolution, offering a gigantic viewable area with 4 times more information and workspace than a Full HD screen. Due to the high DPI (dots per inch) the monitor displays an incredibly sharp and crisp image. Featuring 1ms response time and FreeSync™ technology, it ends choppy gameplay ensuring fluid and accurate transition between images. With the Black Tuner functionality the brightness and the dark shades can be adjusted, giving greater viewing performance in shadowed areas. USB 3.0 HUB, integrated speakers and a headphone socket ensure compatibility with any Desktop PC or Notebook. The GB2888UHSU is perfect for gamers and demanding users who settle only for the best specifications.
4K
UHD resolution (3840x2160), better known as 4K, offers a gigantic viewable area with 4 times more information and work space than a Full HD screen. Due to the high DPI (dots per inch), it displays an incredibly sharp and crisp image.
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
FreeSync™ Technology
AMD FreeSync™ technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama G-MASTER GB2888UHSU-B1 Gold Phoenix - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 60 Hz, HDMI2/MHL: 30 Hz, HDMI3: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, HDMI (MHL), VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
66.3 cm x 23 cm x 41.35 cm
7.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class B
61 kWh
42 W
Diagonal Size
28"
Viewable Size
28"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, black level, aspect control, blue reduction
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
Picture in picture, picture by picture, HDCP, Eco-Mode, Overdrive technology, 10-bit gamma, Advanced Contrast Ratio (ACR), X-Res Technology, Flicker Free technology, blue light reduction, i-Style Color, Black Tuner
66.3 cm x 23 cm x 41.35 cm - with stand
7.7 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA (HD-15) , DisplayPort , 2 x HDMI , MHL / HDMI , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphones (mini-jack) , Audio line-in (mini-jack)
Mechanical
Tilt Angle
0/+17
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x audio cable , 1 x DisplayPort cable - miniDisplayPort to DisplayPort , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB cable
42 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
Dimensions & Weight Details
Without stand - width: 66.3 cm - depth: 6.05 cm - height: 38.35 cm , With stand - width: 66.3 cm - depth: 23 cm - height: 41.35 cm - weight: 7.7 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama G-MASTER Golden Phoenix 28 Bundle deal on iiyama G-MASTER Golden Phoenix 28" 4K 3860x2160 1ms HDMI
£400.93
BRMT C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BRMT C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.66
BRMT C2G 5m Select High Speed HDMI with Ethernet In Stock £22.28
BRMT C2G 10m Select High Speed HDMI with Ethernet In Stock £42.77
BRMT C2G 15m Select High Speed HDMI with Ethernet In Stock £57.94
BRMT C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 28in
Response Time: 1ms
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 300 - 500
