iiyama G-Master GE2288HS-B1 21.5" 1920x1080 VGA DVI HDMI 1ms Monitor
Quicklinx: CC20WS00 Mfr#: GE2288HS-B1
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI
11 in stock
£85.38 ex VAT
£102.45 inc VAT
The Black Hawk is the perfect companion at your side. Hard-bitten and trust-worthy, it will make your enemies shiver. Famous for being a very capable hunter with extremely good vision the Black Hawk eliminates your enemies with a stunning 1 ms response time. And if darkness falls across the land, the Black Tuner function allows you to adjust brightness in the dark shades enhancing detail in shadowed areas making sure no foes remain unseen. So login to the world of games, put on your headset and immerse yourself in your favorite game displayed in beautiful clarity.
  • 1 MS
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance
  • Black Tuner
    The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • OverDrive ON / OFF
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama G-MASTER Black Hawk - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D
Display Position Adjustments
Tilt
51.3 cm x 16.95 cm x 36.45 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, WEEE, TUV Bauart, CU
Display Type
Energy Class
Class A
27 kWh
18.8 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, FreeSync Technology, Black Tuner
3.2 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x HDMI cable , 1 x audio cable
18 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama G-Master GE2288HS-B1 21.5 Bundle deal on iiyama G-Master GE2288HS-B1 21.5" 1920x1080 VGA DVI HDMI 1ms Monitor
£185.14
CC20 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.06
CC20 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.43
CC20 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.11
CC20 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.95
CC20 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
CC20 C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.66
CC20 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.49
CC20 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.71
CC20 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £52.89
Diagonal Size: 22in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 50 - 100
