Product
iiyama G-Master GB2488HSU-B2 24" 1920x1080 VGA DVI HDMI DP 1ms Monitor
Quicklinx: CC21WS00 Mfr#: GB2488HSU-B2
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£241.06 ex VAT
£289.27 inc VAT
The 27" G-MASTER GB2788HS known as Red Eagle is a real game changer, giving true gamers the competitive edge they need to make split second decisions. It spikes down on your enemies with a blistering 1 ms response time, ensuring fluid and accurate transition between the images.
Armed with FreeSync technology and 144Hz refresh rate, this powerful predator has no mercy for ghosting effects or smearing issues. Perfect vision manifested in the ability to adjust brightness and the dark shades with the Black Tuner delivers greater viewing performance in shadowed areas. No matter which you prefer: RTS, FPS, MOBA and MMO - choose Red Eagle and rank yourself top of the gamer community food chain.
  • 144 Hz
    Rapid refresh rate and frame rate guarantee smooth, blur free and judder free graphics, with lower latency and lag improving response times for fast paced games. Especially suited to the fast pace games like FPS, racers, MOBA and sports where the 144hz refresh rate delivers the crisp and sharp images needed to raise your game. For 144 fps game-play it is required to have a graphic card that supports dual link 144Hz DVI.
  • FreeSync technology
    AMD FreeSync technology puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
  • 1 ms
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
  • Black Tuner
    The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • OverDrive On/Off
    When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
  • Speakers and headphones
    Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
iiyama G-MASTER Red Eagle - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
35.3 W
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
56.8 cm x 23 cm x 38.5 cm
5.6 kg
DDC-2B, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class B
52 kWh
35.3 W
Diagonal Size
24"
Viewable Size
24"
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 145 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, black level
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Dutch, Japanese
HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), X-Res Technology, blue light reduction
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DVI-D , DisplayPort , 2 x HDMI , Headphones , 2 x USB 2.0 , Audio line-in
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
34 Watt
Included Software
Driver
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP, Microsoft Windows Vista / 7 / 8
iiyama G-Master GB2488HSU-B2 24 Bundle deal on iiyama G-Master GB2488HSU-B2 24" 1920x1080 VGA DVI HDMI DP 1ms Monitor
£340.82
CC21 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
CC21 C2G HDMI to DisplayPort Adapter Converter In Stock £37.46
CC21 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.65
CC21 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.72
CC21 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
CC21 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.32
CC21 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.20
CC21 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.75
CC21 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.89
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: iiyama
Price Range Ex VAT: 150 - 300
