No matter if you are a newbie or an old wolf in the world of gaming, the 24.5’’ Black Hawk G-MASTER G2530HSU is the perfect companion at your side. Capable of displaying Full HD images at 75Hz refresh rate it will always have your back. Armed with Black Tuner function and FreeSync Technology with a stunning 1 ms response time, the Black Hawk guarantees you will see every tiny detail even in the shadowed screen areas and will be able to respond to the changing situation in an instant. Triple input support (VGA, HDMI, DisplayPort), speakers, headphone connector and a USB hub are all included. So stay in control, keep calm and get in the game!
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance. -
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier. -
Predefined and custom gaming modes
Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memmorize your own settings.
- iiyama G-MASTER Black Hawk G2530HSU-B1 - LED monitor - Full HD (1080p) - 24.5"
- LED-backlit LCD monitor - 24.5"
- Energy Class
- Class E
- Power Consumption (On mode)
- 18.1 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.283 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.75 cm x 19.7 cm x 40.1 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, RoHS 2011/65/EU, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, CU
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24.5"
- AMD FreeSync
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.283 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 84 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Overdrive technology, game mode, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner
- Black
- 4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA (HD-15) , DisplayPort , HDMI , Headphones (mini-jack) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack) , USB 2.0 upstream (Type B)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable holder
- Cables Included
- 1 x HDMI cable , 1 x USB cable
- Input Voltage
- 18.1 W
- Power Consumption SDR (On mode)
- 18.1 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
- Dimensions & Weight Details
- Without stand - width: 55.75 cm - depth: 5.25 cm - height: 33 cm , With stand - width: 55.75 cm - depth: 19.7 cm - height: 40.1 cm - weight: 4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
