iiyama G-Master G2530HSU-B1 24.5" 1920x1080 1ms VGA HDMI Monitor
Quicklinx: CY68WS00 Mfr#: G2530HSU-B1
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£103.77 ex VAT
£124.52 inc VAT
No matter if you are a newbie or an old wolf in the world of gaming, the 24.5’’ Black Hawk G-MASTER G2530HSU is the perfect companion at your side. Capable of displaying Full HD images at 75Hz refresh rate it will always have your back. Armed with Black Tuner function and FreeSync Technology with a stunning 1 ms response time, the Black Hawk guarantees you will see every tiny detail even in the shadowed screen areas and will be able to respond to the changing situation in an instant. Triple input support (VGA, HDMI, DisplayPort), speakers, headphone connector and a USB hub are all included. So stay in control, keep calm and get in the game!
  • 1 ms
    Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
  • Black Tuner
    The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
  • Predefined and custom gaming modes
    Have it your way! Choose one of the predefined gaming modes (including FPS and strategy) or set and memmorize your own settings.
iiyama G-MASTER Black Hawk G2530HSU-B1 - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class A+
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.283 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Matte
55.75 cm x 19.7 cm x 40.1 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, PSE Mark, VCCI Class B, RoHS 2011/65/EU, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, CU
Display Type
Energy Class
Class A+
Diagonal Size
24.5"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.283 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 84 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Overdrive technology, game mode, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, Black Tuner
4 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA (HD-15) , DisplayPort , HDMI , Headphones (mini-jack) , 2 x USB 2.0 downstream (Type A) , Audio line-in (mini-jack) , USB 2.0 upstream (Type B)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x HDMI cable , 1 x USB cable
18 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Apple MacOS, Microsoft Windows 95/98/ME/2000/XP/Vista/7/8/10
Dimensions & Weight Details
Without stand - width: 55.75 cm - depth: 5.25 cm - height: 33 cm , With stand - width: 55.75 cm - depth: 19.7 cm - height: 40.1 cm - weight: 4 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
iiyama G-Master G2530HSU-B1 24.5 Bundle deal on iiyama G-Master G2530HSU-B1 24.5" 1920x1080 1ms VGA HDMI Monitor
£202.94
CY68 StarTech.com Articulating Monitor Arm In Stock £101.86
CY68 StarTech.com Dual Monitor Mount - Stackable In Stock £146.29
CY68 StarTech.com Cubicle Monitor Hanger In Stock £45.29
CY68 StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Response Time: 1ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: iiyama
Price Range Ex VAT: 100 - 150
