Black Hawk - no evil shall pass
The 27'' G-MASTER GE2788HS known as Black Hawk is the perfect companion at your side. Hard-bitten and trust-worthy, it will make your enemies shiver. Famous for being a very capable hunter with extremely good vision the Black Hawk eliminates your enemies with a stunning 1 ms response time. And if darkness falls across the land, the Black Tuner function allows you to adjust brightness in the dark shades enhancing detail in shadowed areas making sure no foes remain unseen. So login to the world of games, put on your headset and immerse yourself in your favourite game displayed in beautiful clarity.
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
1 MS
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance -
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier. -
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
- iiyama G-MASTER Black Hawk - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.35 cm x 24.2 cm x 46.2 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, black level
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Japanese
- Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction
- Black
- 4.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2.5 Watt
- VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x audio cable
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- OS Required
- Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8, Windows 10
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
