iiyama G-MASTER Black Hawk 27" 1ms Full HD VGA DVI-D HDMI LED Monitor
Quicklinx: BRMRWS00 Mfr#: GE2788HS-B1
Black Hawk - no evil shall pass
The 27'' G-MASTER GE2788HS known as Black Hawk is the perfect companion at your side. Hard-bitten and trust-worthy, it will make your enemies shiver. Famous for being a very capable hunter with extremely good vision the Black Hawk eliminates your enemies with a stunning 1 ms response time. And if darkness falls across the land, the Black Tuner function allows you to adjust brightness in the dark shades enhancing detail in shadowed areas making sure no foes remain unseen. So login to the world of games, put on your headset and immerse yourself in your favourite game displayed in beautiful clarity.
1 ms
Fast response time is key to ultra-smooth game. It reduces ghosting and blurring providing the user with a rich experience to improve performance.
Black Tuner
The users can adjust the brightness and the dark shades with the Black Tuner, giving greater viewing performance in shadowed areas and helping to spot the enemy earlier.
OverDrive ON / OFF
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Speakers and headphones
Playing with friends? Use the integrated high quality speakers. Don't want to disturb anybody? Plug your headset to the headphone socket and turn the volume up.
  • 1 MS
  • Black Tuner
  • OverDrive ON / OFF
  • Speakers and headphones
iiyama G-MASTER Black Hawk - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
64.35 cm x 24.2 cm x 46.2 cm
4.6 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B
Display Type
Energy Class
Class B
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, phase, clock, black level
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Polish, Russian, Japanese
Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), blue light reduction
4.6 kg
Audio
Speakers - stereo
Output Power / Channel
2.5 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable , 1 x audio cable
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista, Windows 8, Windows 10
Sustainability Information
ENERGY STAR Certified
BRMR C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
