iiyama E2482HD-B1 23.6" 1920x1080 5ms VGA DVI-D LED Monitor
Quicklinx: BCZKWS00 Mfr#: E2482HD-B1
The ProLite E2482HD is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5 ms response time and advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. The E2482HD is also Energy Star certified. This monitor is a reliable solution for both home and office use.
iiyama ProLite E2482HD - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
56.55 cm x 20.3 cm x 41.2 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B
Display Type
Energy Class
Class B
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, phase, luminance
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
3.3 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8
ENERGY STAR Certified
BCZK C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £8.15
BCZK C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.54
BCZK C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £17.31
BCZK C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
BCZK C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.65
BCZK C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £39.91
BCZK C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.74
