iiyama Dual Screen Desk Top Stand
Quicklinx: D1BJWS00 Mfr#: DS1002D-B1
Hurry, only 2 left in stock!
£70.98 ex VAT
£85.17 inc VAT
The iiyama DS1002D-B1 is a desk stand for two flat screens up to 30". The device allows you to save space on your desk reducing the number of stands to one only and the cable management system makes it easier to keep your workplace tidy. The easy to set-up stand offers broad adjustment capabilities, including tilt, swivel, height and rotation, so you can easily adjust the position of both screens to your preferences assuring comfortable and healthy body posture.
Iiyama DS1002D-B1 - stand (adjustable arm)
Stand (adjustable arm) - desktop stand
Tilt
-85° to 15°
Pan
180°
Lift
14 cm
Rotation
90°
Recommended Use
2 monitors
Recommended Display Size
10"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
AV Furniture
Stand
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desktop stand
Cable Management
Integrated cable management
10"-30"
Tilt
-85° to 15°
Pan
180°
Lift
14 cm
Rotation
90°
Max Load Weight
10 kg
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
Brand: iiyama
Price Range Ex VAT: 50 - 100
