iiyama Dual Screen Desk Top Mounting Arm
Quicklinx: D19XWS00 Mfr#: DS1002C-B1
24 in stock
£58.80 ex VAT
£70.56 inc VAT
The iiyama DS1002C-B1 is a desk mount (clamp) for two flat screens up to 30". Thanks to the arm you can save space on your desk and the cable management system helps to keep your workplace tidy. Broad adjustment capabilities, including tilt, swivel, height and rotation, the arm offers, allow you to easily adjust the position of the screens to your preferences assuring comfortable and healthy body posture.
Iiyama DS1002C-B1 - desk mount (adjustable arm)
Desk mount (adjustable arm)
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Recommended Use
2 monitors
Recommended Display Size
10"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
5-year warranty
ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
AV Furniture
Desk mount
Design
Adjustable arm
Recommended Use
2 monitors
Cable Management
Integrated cable management
10"-30"
Tilt
-85° to 15°
Pan
180°
Lift
20 cm
Rotation
90°
Max Load Weight
10 kg
Limited warranty - 5 years
Iiyama ProLite E2783QSU-B1, XU2495WSU-B1, XUB2495WSU-B1
Brand: iiyama
Price Range Ex VAT: 50 - 100
