iiyama B2780HSU-W1 27" 1920x1080 2ms VGA DVI HDMI USB LED Monitor
Quicklinx: BD0TWS00 Mfr#: B2780HSU-W1
The Prolite B2780HSU is a 27" Full HD monitor with a low power LED-backlit display. It features a stunning 2 ms Response Time, 4 Port USB Hub, a high definition 1920 x 1080 Resolution and comes with VGA, DVI and HDMI connections. The 12 000,000:1 advanced contrast ratio and 300 cd/m2 brightness offer the user clear and vivid images. The ergonomic stand offers 11 cm height adjustment with pivot and swivel, making this screen suitable for a wide range of applications and environments where workplace flexibility and ergonomics are key factors. The Prolite B2780HSU is an excellent choice for universities, corporate, financial and design markets.
  • HAS + pivot
    A height adjustable stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; 60% more in comparison to a 1280 x 1024 monitor.
  • VESA
    VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
iiyama ProLite B2780HSU-W1 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
31.3 W
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.3113 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Voltage
White
64.2 cm x 25 cm x 43.8 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, TUV Bauart
Display Type
Energy Class
Class B
46 kWh
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, gamma correction, input select, colour temperature, phase, clock, aspect control
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Japanese, Chinese
sRGB colour management, HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), i-Style Color
White
64.2 cm x 25 cm x 43.8 cm - with stand
8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Audio line-in , 4 x USB 2.0 downstream , USB 2.0 upstream , Headphones
Mechanical
Tilt Angle
-4/+22
Swivel Angle
340
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable - DVI-D to DVI-D , 1 x audio cable , 1 x USB cable
Mounting Kit
Included
Input Voltage
31.3 W
Power Consumption (Typical)
37 Watt
Power Consumption Stand by
1 Watt
Included Software
Driver
Microsoft Windows 7, Microsoft Windows 95/98/ME/2000/XP/Vista
Dimensions & Weight Details
With stand - width: 64.2 cm - depth: 25 cm - height: 43.8 cm - weight: 8 kg , Without stand - width: 64.2 cm - depth: 6.5 cm - height: 39.25 cm
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 80% (non-condensing)
BD0T C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
