The ProLite XB2780HSU is a 27'‘, eco friendly LED monitor featuring MVA Panel technology. This sophisticated technology provides wide viewing angles and offers superb color performance including superior black and white display. A 5000:1 Native Contrast Ratio means the ProLite XB2780HSU is ideal for Photographic Design and Web Design. Featuring Full HD 1920 x 1080 resolution with VGA, DVI, HDMI signal connectivity and a 4 port USB-HUB, this screen is compatible with a wide range of systems and applications, making it an excellent choice for Universities, Corporate, Financial and Design Markets. The ergonomic stand offers 11cm height adjustment, pivot and swivel.
LED-backlit
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product. -
ACR
Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
HDMI
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. -
VESA
VESA mount compliance means you can easily mount your monitor to a wall. -
PIVOT
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen. -
OverDrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that. -
Speakers
This monitor is equipped with two high quality stereo speakers. -
HAS
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
- Iiyama ProLite B2780HSU - LED monitor - 27"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1080
- Swivel, tilt
- Display Type
- Diagonal Size
- 27"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1080
Audio
- Speakers - stereo
Mechanical
- Swivel, tilt
Environmental Standards
- ENERGY STAR Qualified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
