iiyama B2482HD-B1 24" 1920x1080 5ms VGA DVI-D LED Monitor
Quicklinx: BCZLWS00 Mfr#: B2482HD-B1
The ProLite B2482HD is an excellent 24" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5 ms response time and >12 000 000: 1 advanced contrast ratio, assuring clear and vibrant picture quality and high contrast. The B2482HD is also Energy Star certified. Height adjustable stand with PIVOT function makes this monitor an excellent choice for universities, corporate and financial markets.
  • ACR
    Contrast ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced contrast ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
  • Full HD
    With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
  • LED-backlit
    A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true Eco-friendly product.
  • Key lock
    You can easily lock and unlock the controls preventing unauthorized changes to settings you made.
iiyama ProLite B2482HD-B1 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
56.55 cm x 23 cm x 38.65 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, DDC-2B, VESA DPMS, VCCI Class B
Display Type
Energy Class
Class B
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, phase, luminance
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
5 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand
1 x DVI cable
Input Voltage
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Driver
Microsoft Windows 95/98/ME/2000/XP/Vista/7/8
Sustainability Information
ENERGY STAR Certified
Accessories (4)
BCZL StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BCZL StarTech.com Articulating Monitor Arm In Stock £132.69
BCZL StarTech.com Dual Monitor Stand In Stock £91.00
BCZL StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
Other bundles (1)
BCZL C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
