The ProLite B2282HD is an excellent 22" Full HD LED-backlit monitor with 1920 x 1080p resolution. It features 5ms response time and 12 000 000:1 Advanced Contrast Ratio, assuring clear and vibrant picture quality and high contrast. The B2282HD is also Energy Star Certified. Height adjustable stand with PIVOT function makes this monitor an excellent choice for Universities, Corporate and Financial markets.
HAS + Pivot
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity. Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor. -
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard.
- iiyama ProLite B2282HD-B1 - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.5 cm x 23 cm x 39.35 cm
- 4.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, DDC/CI, VCCI Class B
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR)
- Black
- 50.5 cm x 23 cm x 39.35 cm - with stand
- 4.7 kg
- VGA (HD-15) , DVI-D (HDCP)
Mechanical
- Tilt Angle
- -5/+22
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D
- Input Voltage
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Driver
- Dimensions & Weight Details
- Without stand - width: 50.5 cm - depth: 5.65 cm - height: 31.05 cm , With stand - width: 50.5 cm - depth: 23 cm - height: 39.35 cm - weight: 4.7 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
Accessories (4)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
Other bundles (1)
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
