The TH7067MIS-B1AG is a 70', 10-point touchscreen with integrated interactive EasiNote writing software allowing users to make annotations on files opened directly from a USB device or internal storage. The dispaly supports also playback of presentations, video and almost any other type of content stored on the USB device or internal memory. The high quality commercial ASV LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The Anti Glare screen drastically reduces ambient reflection in high brightness environments without compromising sharp clarity of the content. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The TH7067MIS-B1AG is a perfect solution for educational and corporate use.
Touch technology - infrared
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
Easinote
The integrated interactive EasiNote software turns you monitor into an whiteboard incl. save as image option to internal memory or USB-stick. -
AG coating
The Anti Glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
VESA
VESA mount compliance means you can easily mount the LFD to any mounting that complies with the VESA standard. -
Full HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
- iiyama ProLite TH7067MIS-B1AG 70" Class (69.5" viewable) LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 70"
- Diagonal Size
- 69.5"
- Commercial Use
- Yes - interactive
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15), Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, stylus, wall mount
- Voltage
- AC 100/240 V (50/60 Hz)
- Energy Class
- Class B
- 223 Watt
- Power Consumption (On mode)
- 194 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 283 kWh
- Dimensions (WxDxH) - without stand
- 163.8 cm x 10.25 cm x 96.45 cm
- 64 kg
- Product Type
- Energy Class
- Class B
- 223 Watt
- 194 W
- 283 kWh
- Diagonal Class
- 70"
- Diagonal Size
- 69.5"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 163.8 cm
- 10.25 cm
- 96.45 cm
- 64 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Pixel Pitch
- 0.802 x 0.802mm
- Touchpoints Qty
- 10
- Response Time
- 6 ms
- Display Menu Language
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Audio Controls
- Sound mode, balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 3 x VGA input , DVI-D input , 2 x HDMI input , Composite video/audio input , Serial , Digital audio output (coaxial) , USB 2.0 , 3 x audio line-in , USB 3.0 , USB , VGA output , MHL/HDMI input , Headphones , LAN
- Stylus, wall mount
- Cables Included
- VGA cable , DVI cable , USB cable
- Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
