Product
Brand
iiyama 70" Interactive LCD Touchscreen LFD
Quicklinx: BSHZWS00 Mfr#: TH7067MIS-B1AG
  • 1080p (Full HD)
The TH7067MIS-B1AG is a 70', 10-point touchscreen with integrated interactive EasiNote writing software allowing users to make annotations on files opened directly from a USB device or internal storage. The dispaly supports also playback of presentations, video and almost any other type of content stored on the USB device or internal memory. The high quality commercial ASV LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The Anti Glare screen drastically reduces ambient reflection in high brightness environments without compromising sharp clarity of the content. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The TH7067MIS-B1AG is a perfect solution for educational and corporate use.
Iiyama ProLite TH7067MIS-B1AG 70" Class (69.5" viewable) LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
Yes - interactive communication
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15), Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
AC 100/240 V (50/60 Hz)
Energy Class
Class B
223 Watt
Power Consumption (On mode)
194 W
Energy Consumption per Year
283 kWh
163.8 cm x 10.25 cm x 96.45 cm
64 kg
Energy Class
Class B
223 Watt
194 W
283 kWh
Diagonal Class
70"
Diagonal Size
69.5 in
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Sensors
Ambient light sensor (ALS)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
163.8 cm
10.25 cm
96.45 cm
64 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Pixel Pitch
0.802 x 0.802mm
Touchpoints Qty
10
Response Time
6 ms
Display Menu Language
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Colour Temperature Control
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x VGA input , DVI-D input , 2 x HDMI input , Composite video/audio input , Serial , Digital audio output (coaxial) , USB 2.0 , 3 x audio line-in , USB 3.0 , USB , VGA output , MHL/HDMI input , Headphones , Network
Stylus, wall mount
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
On / Off Switch
