iiyama 65" Black Interactive Display Full HD 350 cd/m2 2477 Operati
Quicklinx: CL0FWS00 Mfr#: TH6567MIS-B1AG
Select:
  • 65"
  • 1080p
The TH6567MIS-B1AG is a 65", 10-point touchscreen with integrated interactive EasiNote writing software allowing users to make annotations on files opened directly from a USB device or internal storage. The display supports also playback of presentations, video and almost any other type of content stored on the USB device or internal memory. The high quality commercial IPS LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The Anti Glare screen drastically reduces ambient reflection in high brightness environments without compromising sharp clarity of the content. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The TH6567MIS-B1AG is a perfect solution for educational and corporate use.
iiyama ProLite TH6567MIS-B1AG 65" LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote control, pen stylus, EasiNote software
Voltage
Energy Class
Class B
173 Watt
Power Consumption Stand by
0.5 Watt
152.15 cm x 9.9 cm x 89.75 cm
43 kg
Energy Class
Class B
173 Watt
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, VGA (HD-15)
Modes
Landscape mode
152.15 cm
9.9 cm
89.75 cm
43 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Touchpoints Qty
10
Response Time
6 ms
Display Menu Language
English, German, French, Italian, Polish, Russian, Spanish, Dutch
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Connector Type
3 x VGA input , DVI-D input , MHL/HDMI input , 2 x HDMI input , USB 2.0 , VGA output , 3 x audio input , USB 3.0 , USB , Composite video/audio input , Digital audio output (coaxial) , Serial , Headphones , LAN
Pen stylus, EasiNote software
VGA cable , DVI cable , USB cable
Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart, CU
Power supply
Input Voltage
0.5 Watt
On / Off Switch
