The TH6567MIS-B1AG is a 65", 10-point touchscreen with integrated interactive EasiNote writing software allowing users to make annotations on files opened directly from a USB device or internal storage. The display supports also playback of presentations, video and almost any other type of content stored on the USB device or internal memory. The high quality commercial IPS LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The Anti Glare screen drastically reduces ambient reflection in high brightness environments without compromising sharp clarity of the content. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The TH6567MIS-B1AG is a perfect solution for educational and corporate use.
- iiyama ProLite TH6567MIS-B1AG 65" LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15)
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control, pen stylus, EasiNote software
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 173 Watt
- Power Consumption Stand by
- 0.5 Watt
- 152.15 cm x 9.9 cm x 89.75 cm
- 43 kg
- Product Type
- Energy Class
- Class B
- 173 Watt
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, VGA (HD-15)
- Modes
- Landscape mode
- 152.15 cm
- 9.9 cm
- 89.75 cm
- 43 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 1400:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Touchpoints Qty
- 10
- Response Time
- 6 ms
- Display Menu Language
- English, German, French, Italian, Polish, Russian, Spanish, Dutch
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x speaker - 10 Watt
- Connector Type
- 3 x VGA input , DVI-D input , MHL/HDMI input , 2 x HDMI input , USB 2.0 , VGA output , 3 x audio input , USB 3.0 , USB , Composite video/audio input , Digital audio output (coaxial) , Serial , Headphones , LAN
- Pen stylus, EasiNote software
- Cables Included
- VGA cable , DVI cable , USB cable
- Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart, CU
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
