The ProLite TH6564MIS-B2AG is the perfect solution for educational and corporate use. The high quality commercial AMVA3 LCD screen guarantees great viewing angles from all sides and delivers superb image performance from anywhere in a class or meeting-room. The solid and robust design is capable of withstanding the requirements of highly-demanding environments. Unlike interactive whiteboards, there are no shadows or reductions in image performance to contend with. The anti-glare feature drastically reduces ambient reflection in high brightness environments without compromising the sharp clarity of the content. By using a finger or stylus, you can write, annotate, draw and present with confidence.
IR touch technology
The infrared technology uses infrared backlight. A touch event is registered with great accuracy when the infrared light is blocked by finger or stylus. This technology does not rely on an overlay or substrate, so it is impossible to physically "wear out" the touchscreen. Moreover the display characteristics remain virtually unaffected by the touch functionality. -
AMVA3
AMVA3 technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Anti-glare coating
The anti-glare coating is used in professional-grade displays to help avoid issues with reflections and external light sources affecting color reproduction, contrast and sharpness. It also makes the screen less susceptible to dust, grease and dirt marks. -
PIP
PIP (Picture in Picture) function allows you to watch images coming from two different sources at the same time. -
Light sensor
The ambient light sensor detects changes in environmental lighting conditions and automatically adjusts the screens backlight brightness to compensate for an increase or decrease in light.
- iiyama ProLite TH6564MIS-B2AG 65" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- Technology
- AMV3
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, pen stylus
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 255 Watt
- Power Consumption (On mode)
- 232 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 339 kWh
- 152.1 cm x 11.1 cm x 83.3 cm
- 64.1 kg
- Product Type
- Energy Class
- Class C
- 255 Watt
- 232 W
- 339 kWh
- Diagonal Class
- 65"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- 152.1 cm
- 11.1 cm
- 83.3 cm
- 64.1 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- AMV3
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.744 x 0.744mm
- Response Time
- 8 ms
- Display Menu Language
- English, German, French, Polish, Russian, Spanish, Dutch
- Colour Temperature Control
- Multitouch, infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Audio Controls
- Balance, bass, treble
- Speaker System
- 2 speakers
- Output Power / Total
- 24 Watt
- Speakers
- 2 x speaker - 12 Watt
- Connector Type
- VGA input , DVI-D input , HDMI input , DisplayPort input , Composite video input , S-Video input , Audio input , Audio input , Component video input , Remote control , Serial , USB , VGA output , Composite video output , Audio output
- Pen stylus
- Cables Included
- VGA cable , DVI cable , USB cable
- Plug and Play, DDC-2B, VESA DPMS, CB, TUV Bauart
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0 °C
- 40 °C
- 0 - 85% (non-condensing)
